CShallies
 - Apr 29, 2023
 - SW Florida
 - Fleetwood
 - Southwind
 - 33'
 - GMC
 - Yes
I purchased a 1995 Fleetwood Southwind and, as I expected, there are some definite issues with it. I still probably got the deal of a lifetime on it regardless, but I do have a few things that I need to address, and I have no idea where to begin. For starters, we are full time in the RV, so liveability is a must.
1. The hydraulic leveling panel has been removed, is there a manual way to lower the levelers?
2. When I went to the dump site at my campground, I was surprised to find that I couldn't remove the cap to attach the hose because the tanks are draining directly against it. My assumption is that the blade valves are no longer working, but that leaves me unable to utilize any running water, as the only way to drain the tanks now, is to to of the cap, and fire hydrant anything in a 50' radius with the nasty contents of my tanks. Any suggestions?
3. My water heater seems to be sporadic. When I say sporadic, I mean it worked one time, for 30 seconds, then never again. Oddly, it was about the 50th time I used the hot water when it worked. So it's not like it died after the first try. It just suddenly have me hot water for 30 seconds, then never again. I've done everything I could find on the net to troubleshoot, but unfortunately, every single thing starts with, "there's an on off switch outside in the panel, on the lower left". Simply put, NO THERE Isn't. There is no switch anywhere on or around the water heater or outside panel. The water heater is full, and there are no blockages anywhere. Ideas?
4. The Dometic RM 2807 heats up, instead of cooling down, literally to the point where you can cook a turkey in the freezer and you will burn yourself if you touch the metal shelf inside. The refrigerator section reeks of ammonia when it's turned on, so my assumption is, there's a leak, so the ammoniated system is not pulling heat, but generating it instead. Again, there are no blockages to the vent system, or the drain/vent hose, and the thermistor is in place, so I'm at a loss on this one as well.
Please help before I just drop an M-80 into the fuel tank, and chalk up the loss.
