Question Tire Air pressure Source
Joe Dutchstar
Florida
Dutch Star 4311
Cummins
2018 Ford Flex
When we ordered the Newmar DSDP, I added a front air chuck located in the generator pull out area. My thinking is it would be nice to have an external air source for tires and other momentary uses. If the engine is running or not?
Am I correct in thinking that the on board air pressure reserve can be used to top off tires? Or will I still need to drag around the Viair compressor?
@Joe Goodxrvn I'm not sure what the option (or special) is that you ordered. On my 22 Dutchstar there is a air system quick connect in the generator area but I did not add it when I ordered the coach. My experience on my 15 Ventana which had the same air system quick connect was that the system can be used to top off tires BUT.. When I tried to use the onboard air, particularly for the front tires which I run at 110psi I would have to ensure the onboad system was at full pressure i.e. ~130 psi then add air to the tire. The onboard system would quickly fall below 110 since it did not seem to have sufficient volume to complete the tire "top off". I then would have to get in the coach, pump the brakes a few times to get the air system to drop sufficently for the onboad air compressor to recharge the system & cut off, then repeat the tire fill attempt. SO yes it can be done but it's a pain. Now I carry a 110v air compressor to handle any needed compressed air requirements. ARD or others my chime in regarding the option to add an "air intensifier" which I believe resolves the need to cycle the onboard compressor. Never had an intensifier so can't offer any insight on that option.
In my experience, especially for the front tires, the RV did not provide enough pressure without the engine running...especially after the first few pounds are used.
thank you. This answers my question. I’ll probably just get a 120v compressor.
I've heard some adding a "doubler" that makes the on board air tank system capable of use for filling tires, etc. I think this is sold by Newmar but it may be a chassis vendor part.
Pricey mod, engine still has to be running. I have had porter cable compressor that goes to 150psi and has worked well.
I purchased mine at Spartan and they installed it. They also carry it in the parts department at Newmar. The doubler works great. I can air up my tires very quickly now.
I simply bought the fittings/adaptors and a 50' hose at my local Ace Hardware. I check and fill when engine is already idling. Fills the tires super quick and I gave my old compressor to my son-in-law for his RV; one less thing I haul around in my storage bays. The hose stores very easily up front by the factory installed air chuck near the generator with the use of these really strong heavy duty magnetic holders I picked up on Amazon:
Amazon product ASIN B0C3MQLQMZ
Best,
-Mark
Has anyone tried using nitrogen in there tires on these rigs. We use it in aviation for several reasons. I am considering swapping out the shop air with nitrogen to see if perhaps the tire pressures stay consistent and possibly cooler. I have a nitrogen set up at the hangar I will need to see what volume they will take and figure out the cost/benefit ratio. I will do the front tires first to see if it makes a difference.
Question, So my coach came with the air port in the generator bay and 15 foot coil hose with fittings was included with the accessories. I wanted to use the onboard air on the rears tires but the only air fitting is the one for the towed rig at the hitch. The male fitting for the hose provided does not seem to be compatible though. what style fitting is that on the hitch, is it unique to the brake systems? I don't use brakes on my toad.
Thanks
[no expert on this]
I think you could but I recall seeing a video that you would need to completely deflate your tires to get the air out prior to putting Nitrogen in.
Thanks
I realize this is mainly on car tires but it’s worth a read when thinking about adding nitrogen.
