Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
As we were preparing to leave on our most recent trip, we started up the generator to run the AC (and give it some exercise) and after starting and running for a about 5 minutes, it quit…. I opened the hood to take a look and it was flashing a service code of 2, then 4 blinks. I reset the code and ran the generator again and it quit in the same way. After not finding the 2-4 this combination, I called Cummins and was told it was a coolant temperature sensor.
The part appears to only be about $50, but it is located in the back of the motor (although on top), but since the Ventana does not have a generator slide, it makes it almost impossible to get at.. I am not sure I can get the pan cover off of the top to get in there.
I called a few RV places (including NIRVC and Freightliner Gafney) and neither would touch it…and recommended going to a Cummins center. I called the Cummins in Charlotte and they said it they may have to drop the generator to get at it ( that does not surprise me) an that they would have to call me back with and estimate. Still waiting nearly 24 hours later…. Anyway, I am glad I have my solar and lithiums as I can run the front AC from there for now.
Anyway, does anyone have any thoughts? Has anyone taken the cover off, especially if you do not have a generator slide?
I am sure this will cost a ton of money to have done for a stupid $50 part so I begin to wonder why Newmar does not put generator slides on all their models. It is not a luxury feature but necessary for work to be done.
