Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
Yes, the auto switch is working but…are you saying I could possibly have the generator running, as well as the shore power plugged in, then I can unplug and the generator will then switch and supply the power? I was afraid to try that with both sources running at the same time…Nope, you got it. I would check the transfer switch now. It is supposed to automatically go to generator when the shore power is removed.....or if you have an old system, you have to plug the generator in manually in the electric bay.
Yes, AC units were working fine in the heat. (I did have to put in new caps in the rear unit but they both worked fine after that.I was just thinking!
Your system was working during the summer right? So is the temperature warm enough for the A/C to kick in?
My Winnebago had 2 ac units, and 30 amp service, where both could be turned on at the same time. First thing I had to do was replace the cord cap on the ambilical cord. Because the vents were factory, I assumed that was a Winnebago blunder.If you have 2 AC units you probably have a 50 amp unit but I have seen 30 amp units with a switch where you select which AC is going to run.
I wouldn't have a clue! I always traveled with it to follow the temperature! As I recall I seldom turned them on. I was always off grid! Did run the generator if needed, but at 2hrs a gallon, the economics turned me off completely!!!They must have been less then 13,500 units. I can't turn on anything in my camper that takes any power if the AC is running. That is microwave, hot water heater.
