Problem 1993 Holiday Rambler 34 Gas Tank Fill Issue
I look at it like a bad ground. Its the whole circuit, not just he positive side.
I had the slow fill tube on water fill up and it was the vent line was blocked. On 2 campers.
I would suggest that by straightening out the fill tube you allowed it to vent by itself. But the vent tube was not venting or it would not matter. Did you have a vent tube on that print washer?
I get that. A vent tube that closely follows the fill, has the same problem as a rule. Thus the problem is.
I lean toward Kevin's suggestion that the problem may have cropped up as the result of an in tank fuel pump replacement. Easy enough afterwards for the person pushing the tank back up to compress the vent hose, unseen, with an interference pushing against the hose making the hose initially fish mouthed at the compression spot but still venting enough to not be a problem. As the hose yielded further and took a set, the fish mouth may have later fully closed.
Troubleshooting is often all about determining what isn't the problem. Unclamping the vent connection at the hard pipe interface seen in the photos and then connecting a temporary hose, twice, to mouth blow test for vent line blockage BOTH directions at that connection would be the first test to perform.
If vent path is blocked when blowing toward the tank, unbolting the tank and dropping it down for the fix would be next...
Still working on the fuel tank. I pulled the soft portion of the vent tube and was able to blow air both to the tank and towards the fill door/opening. I found some cracking in the tube right near the end that attaches to the hard section so I cut that off and reattached
I strapped the fill tube up to get all but like 1” of the p trap taken out
Ran to the gas station to test fill. No luck it still clicks off after only 5 seconds
The latest thing I’m wondering about is IF the tank was out before could the tank height position be reinstalled to high? In this pic it almost looks like the tank is lower on the near side which is where the fill and vent tube attach. I also can see some shiny metal on the shroud in front of the gas tank. Maybe this can be lowered? Thank you for any help and thoughts 😁 IMG_2578.jpegIMG_2580.jpegIMG_2581.jpeg
Tried a couple more things yesterday and no luck. From other online sources, some suggested to use the coach leveler jacks on the driver side to lift the coach making the fill tube angle even more down hill when fueling at the gas station. Also, I strapped the fill tube and vent tube from fuel door to tank separately to both attain no dips in the vent line and keep any p trap from happening in the fill line. Ugh
Update This morning I found online some information from owners with Ford 460/F53 chassis motorhome…the charcoal canister can become clogged with vent lines and cause this issue. That is something I’m going to check into AFTER I find the darn thing…somewhere on the frame rails I understand?
Because I Am who I Am. I seldom have patients for such things. The canister can be destroyed by overfilling, so that seems reasonable.
In My methods I would cut a section out of the floor and reroute the fill and really fix the problem rather than make something I could survive.
I wish you luck!
Located the charcoal canister…turns out there are two connected in series?. I looked over the entire frame front to back with internet searches saying it would be towards the rear/fuel tank. Nope. Oh well. Passenger side frame rail near engine and could see once the engine cover was removed…see red highlights and pics with a hose I am going to try fueling with disconnected tomorrow. Fingers crossed. Suggestions/comments always appreciated. IMG_2601.jpegIMG_2604.jpegIMG_2602.jpegIMG_2599.jpeg
The day started off with yet another disappointment at the gas station. 😔 Disconnecting the vent line at the EVAP canister did not solve my problem
I returned home ready to call the RV Service place near me and make an appt ie give up on trying myself anymore. Well for some reason I kept thinking about the main fill tube and the odd black plastic 3 prong thing that is press fit into the metal section about 12” down from the gas cap…it looked like it was missing a part but no signs of broke off edges. Anyway, I kept searching the internet for anything about anti siphon parts but none of the images looked like what I had plus the few searches suggested that F53 stripped chassis would rely on the motorhome to “plumb” the final fill and vent. I decided to pull the fill and vent apart one more time and make sure nothing was way down in there near the opening to the fuel tank….well after poking around carefully with several picks and things I removed something that looks like a kids super ball!! See pics I’m thinking this check ball is supposed to be held in the fill tube by the 3 pronged black plastic thing that I kept thinking about. Back to the gas station and problem solved as I filled the tank at full speed with no hint of clicking off or spitting gas back. Sooo pleased and wanted to share for the next guy like me very frustrated with 30 minute fill ups It was never a venting or ptrap thing after all 🤷‍♂️Fingers crossed never again!!
PS I did not reinstall that ball but keeping it on IMG_2605.jpegIMG_2608.jpegIMG_2606.jpegmy workbench as a sort of trophy for all this problem solving. Thank you to all who helped along the wayIMG_2609.jpegIMG_2607.jpeg
