2022 LADP - Paint the way it should be
I don't understand @redbaron, if Newmar "intends" to deliver all new coaches that way, why wouldn't they have to ability to do it?
The reason i say the intend to deliver it without flaws is based on their advertising of a masterpiece finish, with a cut and buff. These terms are very clear to paint and body experts, and imply a finish that exceeds automotive standard finishes.
Newmar agreed with that assumption when I discussed my concern, and agreed to fix it.
That is where the 2nd statement comes in: "Newmar does not have the ability to do it properly".
Newmar initially wanted me to go back to Nappanee. I have seen their work, and their recommendations for repair. They use an approach to make it look good for short term with no concern for long term. They also do not have skilled people trained to use the polishers, and burn thru paint, making it worse.
I have seen many coaches go thru the Nappanee repair process, and was not willing to.
Until Newmar takes paint seriously, they will not invest in the ability to do the work properly. Among the many investments to be made are facilities, personally, and quality standards that are in line with automotive repair guidelines established by insurance companies for collision repair.
When I was working with Mark @ NIRVC he shared with me the standard they would use, and won my business.
What is in the box and the significance of the paper taped to the coach? Is part of a treatment of some kind? I am unfamiliar. The mirror finish is phenomenal.
That was a sheet of PPF for the door. It was cut and one side of peeled off, ready to apply to the door.
PPF has 2 protective layers that are removed when it is applied. This is very similar to window tint.
@redbaron , I would like to resurrect this thread and ask a few questions if you will indulge me.
1. To your knowledge, has NIRVC held to the paint standard? Mark left, and I’m curious if momentum was maintained post-Mark.
2. The PPF you used sounds good. What brand did you use and where can I find application instructions?
3. I’m getting the Bob Moses treatment later this summer. The road I live on is lined with trees and other vegetation which often encroach into the travel lanes. As a result, I often have scrapes, mostly on the passenger side, up high. How feasible do you think it would be to use PPF as a preventive or mitigation against this threat to the paint and ceramic coating?
