TXbound
RVF VIP
- Jan 6, 2021
- Winnebago
- Adventurer
- Chevy P30
- 454 Vortac
- Yes
I have to check the bypass valve and I have to double check to see if the igniter makes any sound. Thanks.If the water is only warm, it will be either the thermostat is bad OR the bypass valve is not fully closed. For the gas burner, how long has it not been working and does it make any sound when it tries to light?
Not yet as we just bought it this month.Have you ever changed your annode rod? Maybe your tank is so covered in lime scale that the heating elements can't heat the water? I noticed your rig was a 1997 so I thought I'd ask. Of course this doesn't have anything to do with the LP side not igniting.
