Question Accumulator tank for RV fresh water pump?
I noticed in @Joe Hogan's new 2024 Newmar Dutch Star an accumulator tank is installed along side the water pump. I've heard of these and saw them when switching to REMCO. His pump is a Shurflow setup. Has anyone installed one, what benefit do you notice? Something RV'ers would benefit from?
Water pumps cycle less! And pressure stays more consistent! Been so long with one I almost forgot why I put it in.
I have a little one, about quart size. I don't think it does much; a bigger one would would help with pressure and cycling.
I’ve been considering one primarily for when boondocking. The refrigerator water dispenser has a low flow rate and the water pump will slowly cycle with the dispenser pressure/flow rate going from high to low and then back to high again. It would improve the dispenser flow rate as it would maintain the accumulator set pressure. I already have a Remco variable speed water pump so I don’t expect any improvement at the shower or kitchen sink.
My bathroom sink cycles because the demand is too low. I asked Remco about it wondering if there was an adjustment on the pump, or what to do. Remco said to open the kitchen faucet at the same time as a test, and yep, it stabilized. Nothing you can do. I think I'm going to get an accumulator and see how it goes. Why not?
WOW, I have a class B, not an Class A. and that looks like something one would use on 1"- or - 2" Pipes. Our pipes are 1/2"-pipping.
And I have an 83' fifth with no basement, but I live off grid and like some comforts.
I've used them on several different 5th wheels. I have found it helps cycling somewhat but quietens the pump substantially.
Also helps conserve water because it is better regulated
Plumbing is always a puzzle but as I have a Remco pump I'm going to stay with their brand. Just ordered 1 x accumulator and 2 fitting kits and see if I can get this puzzle right in under 3 tries!
I'm pretty much ready to install my accumulator but as I'll be winterizing next week for long term storage I'm going to hold off until ready to resume RVing. Interesting that you need to precharge the reservoir, seems like 30psi is the recommendation. Also may need to check this at times so need to consider a mounting location that allows access to the valve. Hopefully Newmar is educating its customers this is not an install and forget item, it will require maintenance to operate properly.
Directions recommend using a high pressure braided hose so I have some on the way:
Amazon product ASIN B0BZHXS6Y9
I also picked up some more fittings so I'm ready for the task when the time comes. Plumbing is always a puzzle that requires several trips to find fittings so hope I'm armed and ready! :)
Amazon product ASIN B0CJN2HMWJ Amazon product ASIN B0CJN7SVMZ
Hoping I can install through the shower panel area when removed otherwise I'll have to remove the wet bay board which I'm fine with, not hard, done it before. Again, just need careful attention for future pressure management.
My former house was on well water which utilized a whole house accumulator tank. It was pretty much a set and forget. I occasionally looked at the attached meter to verify it was properly pressurized, but I never had to adjust it. I would expect the same here. You could extend the schrader valve to a readable location (wet bay panel?) and also use that extension to adjust the pressure if needed. Just a thought.
I wonder if the psi of the water from the pump also acts to keep the accumulator pressurized? Good to know it's set and forget.
The water pump doesn’t act to keep the tank pressurized, it only acts to keep the tank filled. The accumulator needs to have the pressure set such that it is less than the input (water pump and/or city water) otherwise the accumulator tank will not work. The internal diaphragm is pressurized via the schrader valve and must be less than the input pressure in order for the diaphragm to give way to the incoming water that’s filling the tank. The tank will output its water at the set diaphragm pressure or the input pressure if it’s less (in which case it couldn’t fill the tank because the input pressure is less than the diaphragm pressure). The goal is for the tank to be filled at a high pressure and the tank provides a constant pressure to whatever it feeds. For my former house, the well pump was feeding the tank at a much higher pressure. The tank was sized such that it provided a constant pressure for a few minutes before the well pump had to turn on again.
In an ideal situation the accumulator tank would feed the whole coach and be set at 55-60 psi. The water pump would be set at say 65 psi and fill the tank and there would be enough capacity in the tank to minimize how often the pump needed to run.
Here is the instruction sheet with the REMCO accumulator I ordered. Bottom of the sheet is the info of interest.
