Rustymayes
RVF VIP
- Sep 11, 2022
- Vacaville, CA
After my last trip, while I was placing blocks under the jack system, I noticed a pretty large air leak sound that had not been prominent in the past. Today I decided to look into it so I raised the coach up a bit higher with the jacks leaving the wheels on the ground. I started the engine to pump up the system and it took very little time for the pressure to build up what is about 135 on the gauges before the relief blows. I shut down the engine to listen for leaks but oddly, I could not hear even the faintest of hissing. I then lowered the coach and dumped the air with the manual dump button on the jack control pad, fired up the engine and waited for the coach to lift to ride height on the air bags. The pressure built up in the system and both guages read 135 but the coach did not lift at all. I am wondering if a solenoid somewhere is inoperative. I cant drive the coach like this for sure. I did notice that last trip on Friday, I stopped after a 60 mile drive, stopped for about an hour and then went to move the coach to reposition on the property and the suspension was bottoming like the airbags were flat. After about five minutes they raised enough to not bottom any and I parked and leveled the coach for and overnight stay. In the morning I started the coach and went about my normal routine in stowing the jacks and retracting the slides with no issues. On the drive home though I noticed that my guages were not reading the same air pressure. One was about 10 to 15 shy of the other. I could not remember if they typically read 150 or just shy but I always thought they were about the same. Any insight would be appreciated.
Thanks
Rusty
Thanks
Rusty
