MarkMaxPayne
- May 24, 2023
- Beaverton, OR
- New Aire 3543
- 36'
- Spartan
- Fiat 500 Turbo
I tried a cheap fix today, but will have to see if it stands the test of time. I ended up buying 2 packs of these magnets with countersunk holes in the center and screws off of Amazon. 2 packs as each ceiling panel has 22 magnets. Amazon product ASIN B09LYWGGFR. It's the 10mm diameter ones to match the size of the factory ones, not the 8mm.
I ended up collecting up all the magnets that Newmar had used from either where they had ripped out of the panel pockets and stayed attached to the metal ceiling frame or by using a pair or pliers to pull them out of the pockets in the wooden drop panels.
I then marked a drill bit to the depth I wanted to drill pilot holes for the screws that came with the new magnets. After drilling all the holes in each of the magnet pockets in the wooden drop panel (centered in the existing now empty pockets) I then pushed the new magents into the pockets and screwed them into place. No more magnets coming out of the wooden drop panel!!!
Now here is where it got sketchy and plans changed. When I remounted the drop panel into the ceiling it was pretty obvious the new magents were not going to be strong enough as they were much weaker than the previous magnets. Solution? I simply stacked each of the old magnets onto each of the new magnets. Now when the panel is first inserted Newmar's previous magnets grab hold of both the metal frame in the ceiling and onto the new magnets and screws firmly attached to the wooden drop panels.
When I remove the panels all of Newmar's old magnets stay attached to the metal frame in the ceiling. That said, I am not left with a worthless drop frame with empty magnet pockets as my new ones are still firmly attached. To reaffix the drop panel just push it back in place and I can hear all the magnets, new and old, re-engage again.
The drop panel hangs about 1/4" lower than it used to, but the metal mounting frame bracket was recessed enough for this not to matter.
I suppose one could to similar with metal washers and screws or metal plates and screws vs these weak magnets with counter sunk holes in them, but I do believe this provides a stonger, less frustrating hold than the factory solution.
Best,
-Mark
Best,
-Mark
