Any updates on AC replacement for failing Penguin IIs?
newmarokie
southern oklahoma
newmar
Dutch Star 4018
40'
450 hp Cummins
2017 Colorado, 2013 Dodge 1500 quad cab
My zone 1 AC is getting blinkey. I replaced zone 2 a year ago and had to put an AC only unit in. I did see on Camping World that they have a RJ 11 to RJ 45 adapter to get you in and out of a freshjet unit and keep using the CCC2. The freshjet now has a built-in control box that apparently wasn't included in older models. Has anyone successfully made this transition?
Following for when the inevitable happens. Also wondering if the Micro Air thermostat will work with the new units.
Supposedly the new units will work with Micro Air thermostats. I was led to believe early on that everything had to be replaced. But info is slowly coming out about compatibility. A Coleman guy at the Quartzsite RV show told me they would still plug in. I think the control box is different with a flame sense in it and may not be compatible with some thermostats.
Well, I can't give a report. Got on top of the coach and checked the ac out. It just needed a capacitor and a blower motor. I had a blower motor out of the rear unit that I had put in about six months before it gave up the ghost. So for $43 dollars I have cold air on again.
