- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
To maximize storage space my goal is to take advantage of wasted space which is the area above storage areas in the basement that typically can't be used. As I recently installed a Dometic CF-80 cooler as outlined in this thread I wanted to add a shelf for the space above it as many have done by Newmar. I already had the Hafele garage storage strips along the wall so I did have some storage in use in the higher area but with the Dometic cooler displacing my 3 drawer toolbox I needed to relocate some tools. The other area fit for a shelf is the bay just forward of the pegboard, for my setup at least. This is also where I decided to put my new low profile toolboxes that now hold the tools that came out of the 3 drawer tool storage system. The third area fit for a shelf for upper storage is on the driver's side of the pass through bay. The problem though preventing me from being able to put a shelf in here is the HWH Active Air system board is wall mounted in a way that will obstruct mounting a shelf. Having the solar charge controller and array of its goodies just makes the location of things difficult so no shelf there.
I'd love to see your shelf mods. My setup is temporary until I get home to my full wood shop and the Newmar basement carpet I ordered for this future project. I used 1/2" MDF which looks like is not going to be sufficient for the weight needed from the toolboxes so I'm likely going to use 3/4" plywood when I do the final install. I also put a piece of trim that's about 3/4" tall on the front to form a lip so things can't slide off. Basic angle brackets secure the sides. I was able to go under the central vac system and attach to the board it mounts to on the forward side of that bay.
Looking forward to learning from others that have done basement shelving mods.
https://www.amazon.com/gp/product/B07F85JFV4/?tag=rvf01-20
FYI - I bought this compact circular saw for my project while traveling. I was impressed!
https://www.amazon.com/gp/product/B077TMJGP2/?tag=rvf01-20
