- Jan 19, 2021
- Ventana 3427
- Freightliner XCR
- 6.7 ISB 360/800
- 2001 Jeep Wrangler
I should have picked up on that too but didnt. Anyway sounds like the OP made a good choice.Rich......I'm wrong! I don't know where that came from this morning, (maybe a senior moment), but you have a 12vdc system. (2 batts, +to+ and -to-). That's 12 volts, with higher available amperage. My appologies. (minus-to-plus, is the 24vdc system.)
The rest of what I said this morning is correct. You might want to investigate AGM type of lead-acid batteries, too. They're lighter weight, and still have good reserve power.
Sanda's suggestion of two, 6-volts isn't out of line, either. Two 6-volters, wired in series, still gives you the 12vdc, but equal or higher reserve than the two, 12-volters in parallel. If you foresee doing some boondocking, it might be worth considering.
Roger
To the OP, in case this is new to you, remember when calculating the Ah of your battery bank, if the batteries are wired in parallel the voltage stays the same but the Ah doubles (the way it is in the pic); when you wire the 6v batteries in series you double the voltage (to get your 12v) but the Ah stays at the value of one battery.
