Good morning,
So I have an issue maybe some of you have encountered. When I unplug from Shore power I am blowing Fuse F6 which by the labels is the Charging / Slide Out circuit. I do not have a slide out, which leaves Charging System.
I replaced the Converter as I thought it almost had to be that and there was a small blackened compnent on the back, so I thought I had it. Well, the new converter is doing the same thing. Blowing the Charging system fuse when switching from Shore to battery. No charging issues. Charges when plugged in. Charges on the TV. Runs great on dual battery setup. AND.... it doesn't blow it every time. Just like 7 or 8 out 10.
Sounds like a short somewhere right? That makes and then loses connection? I'm stumped. Any help?
2017 Jayco Jay Feather
WinU
WinU
