Building a Small RV Park - Year 2
The jury is still out on damage to the fruit trees but it didn't get anywhere near as cold as we were told it would be, so that's good.
On another note, we installed our first electric car charging station. It's not a fancy charger, just a dedicated 50 amp plugin. But it should serve the need just fine.
And while we were at it, I added a junction box about 15' away that can be turned into an second charging station by simply adding the equipment. So yeah, all you folks with electric toads, come on by and sample some good ol' NC car charging electricity. :)
I’m adding another set of hook ups and a gravel pad next to my RV parking for visitors and I included a 50amp outlet in front just for EV charging. So far used several times by a volt and works just fine.
Remember these? Sure you do. And now their jumping off the pallets and lining themselves up on that tiny little pad.
Pavers are the bomb. They make so much sense for an rv pad as you can pull out and replace stained ones. Every park that we have stayed in that had paver pads had that “classy“ look.
Yes, they do. But in this case, that is not what these blocks are being used for. :-)
Yes, they do. But in this case, that is not what these blocks are being used for. :)
My bad. I see now @Jim. Wake me up when you are finished….
Paver grill stands?
Also congrats on the start of the new season.
DOG HOUSE!!!!
Crematorium. Has anyone seen @Jim and Dexter in the same room?
Getting closer every day. Believe it or not, I'm only through 2 pallets of brick so far. I'm beginning to wonder if my order was filled correctly!
Puppet theater?
