I'm sure there are a million of these and I know the it is easier to get a doctorate in rocket science then figure out what Ford is trying to say, but maybe someone can give me a solid answer
I convinced the wife to go camping as long as I rent a TT. Found the following for rent.
4705
Dry Hitch Weight (lbs)
625
Gross Vehicle Weight Rating (lbs)
5995
Cargo Carrying Capacity (lbs)
1290
Truck is 1400 payload GVWR 6500
Trip is an hour away all highway little to no hills or mountains
Note my truck has the 3.55 Ratio and states 7500 (16 F150 Screw 5.5 3.55 2.7L)
Will have WD hitch
Everything I read I am ok, just want to check with you guys while I can still cancel...
I don't expect to be totally loaded down, There is a bunch of us going camping so I dont need to carry a lot of gear, also thinking about heading up early to set up and letting the wife drive with the kids in her own car probably 500 lbs in people and animal plus some light gear most will be in the trailer.
Thanks!
2016 Jayco Jay Feather 254
Unloaded Vehicle Weight (lbs)
Will have WD hitch
Thanks!
