Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I got the central vac option with my 2017 and it works well. It's powerful, no complaints on how well it works. The problem is the storage of the hoses/components, I guess. I kept them in a rubbermaid under the bed so it was just a little out of the way for quick pet hair cleanup etc. I later switched to a Dyson portable and that's much easier to grab and clean. I moved the satellite and other components in my bedroom AV compartment to be side wall mounted with velcro which opened up that compartment for other use, it stores the dyson and components. I guess I could probably do the same with the central vac hose and parts.
Did you get the Central Vac and do you use it?
If you use another vacuum option which one are you using and where are you storing it?
