DC only fridge..bad idea?
Broncodriver76
Looking to replace my Norcold in my 2013 Voltage. There’s a Furrion DC only available to me. I’ve always kind of wanted to get all propane out of my rigs. But I’ve also had a full size residential fridge in another RV and it played hell with my batteries. Is a DC only a bad idea if it’s 12 volt? Shouldn’t drain my batteries as quickly as a residential I’m assuming? I do have an onboard generator.
Anyone have the Furrion FCR10DCG & love it or hate it? Thanks
I wouldn't have a 12 volt fridge for what we do. Most of our camping is on federal lands with no hookups. We do have lithium batteries with 330 volts of solar but the 12 volts of the fridge would eat that up pretty fast.
I replaced the original gas/electric cooling unit on my Norcold 1210IM with the JC Refrigeration 12v compressor about 2 years ago. Have been very happy with the results. We boondock/dry camp about 80% of the time so it runs on our 400ah lithium charged by 1600 watts of rooftop solar. We also have a 12v portable Dometic fridge/freezer in the basement we run at the same time and have never run out of 12v power. The amperage draw is a lot less than people think because the compressor cycles on & off vs the conventional gas/electric is always on. The conversion cost was about 70% less than replacing the entire fridge.
I have a 12 volt fridge in my Jayco. I put in 2 200 amp hour lithium battery's. There is 380 watts of solar mounted flat on the roof.. Just to see how it all worked I turned on the fridge and let it run. After 3 1/2 weeks I finally shut it off.
Depends on the fridge. It's not about the power drain, but the insulation.
My preference is a standard 115vac fridge. The reason is the required comparison tag for the fridge that can be found online.
The annual cost for power is what I pay attention to. Why? Because it tells multitudes about how well insulated.
I have a chest freezer, an upright freezer/ refrigerator( one or the other), and a 32 inch high undercounter fridge running on 1500 watts of solar.
Cloudy days are the only issues I encounter. And then only after 4 days typically.
No lithium, just 200 ah at 24v of carbon lead batteries.
I wouldn't buy a 12v fridge. Most are designed for portable use, and have very little/minimum insulation.
Our RV fridge went bad and I replaced with a residential fridge. Reasoning I could get a 24 cubic foot resi fridge in the same spot my 12 cubic foot fridge fit. I could block off the roof vent and side vents on the rig sealing it up better. The temperature control is much better. (My wife likes her ice cream frozen). We boondock and with the Kenmore Elite fridge and with our basement dorm room type fridge 1.7 cubic foot and misc 12vdc items powered I draw 1-2 amps. We have (4) AGM house batteries and can run 14 hours without needing to charge.
I have no idea why these pictures are the wrong rotation. These typically load in the correct orientation.
