team bradfield
RVF Expert
- Nov 9, 2022
- Dutch Star 4081
- 40'-10"
- Sparten
- 450 cummins
- 2022 Grand Cherokee
I assume you ask for when you store your rig. Small room works.what size/model de-humidifier do you all use?
yes, while at home, we spend most the summer in our pool, travel in fall/spring, don't want to run the AC all summer when not in itI assume you ask for when you store your rig. Small room works.
I personally use one in conjunction with an evaporative cooler.
Not why you would think!!!
I get the cooling, and I get distilled water, all in one!!! Thinking outside of the box!
Look for one that offers a hose connection to drain water outside. Mine is a commercial one with a drain connection, and made of stainless steel. My neighbor has one that has a 2 gallon tank as well as hose bib connection. When she used the tank she had to empty it 3x a day. Her experience is what got me thinking about water recovery.yes, while at home, we spend most the summer in our pool, travel in fall/spring, don't want to run the AC all summer when not in it
same problem I had in FL last fall in the fiver, had to dry the ceiling off every evening, so much condensation around the ac ventsI use two small non compressor type, with tank. WHEN IN FL roof A/C Plus these two barely keep the coach below 50% humidity.
FYI; to prevent mold or any kind of smells you only have to go down below 60% humidity. I set my whole house dehumidifier to 55% so it did not have to work so hard.I use two small non compressor type, with tank. WHEN IN FL roof A/C Plus these two barely keep the coach below 50% humidity. A compressor type would be better, but in a gasser, there is no room.
Interesting. Thanks. At home Inkeep it at 35%. The exception is the room with a lare wooden musical instrument which drinks much water (45-50 % in there).FYI; to prevent mold or any kind of smells you only have to go down below 60% humidity. I set my whole house dehumidifier to 55% so it did not have to work so hard.
