MapNerd
RVF 1K Club
- Nov 17, 2019
- Prince William, VA
- Ventana 4326
- 2020 Ford F-150
- Yes
That’s true in our 2018 Mountain Aires, but I don’t believe the Ventanas use the SilverLeaf control system. I think they are controlled at the switch level.The backlighting isn't controlled by a physical button per se. You press the button and it sends a command to the control panel. The control panel then responds with a command to turn the light off.
So the short answer is no, it cannot be done easily or at all. This is because depending on the age and year of the coach, backlighting works differently in different coaches. This is all determined by what the Newmar requests were for those years and those coaches. Backlighting is usually setup by regions throughout the coach with one of the switch in the region controlling backlighting in that region. This is all setup by the programming each part is initially set with and cannot be changed. Not all switchs can or do have backlighting buttons. Hope that helps and answers your questions.
