NWIP
- Nov 4, 2019
- No Where In Particular
- Dutch Star 4369
- 43’ 9”
- Spartan K2
- Cummins ISL9
- 2023 GMC Sierra
- Yes
Wasn’t sure wether to post new thread or where are you with your Newmar. Friday we had one of those days traveling from Pine Bluff, WY to Kaycee, WY with the winds for most of the route forecast 20-30 with gusts 40+. Decided we would give it ago with plenty of rest stops on the way if it got too bad. First issue was the slide topper cover on the driver’s side kept opening over the bracket designed to prevent this should the magnets not be sufficient. Had to keep stopping (at least 6 times) start generator, open slide a few inches and close. This has been an issue before and some have added additional brackets at front/back of topper cover but I had never experienced this in over 50k miles so I hadn’t added any except on the kitchen slide. I’ll be ordering 2 from Newmar parts on Monday
Next, TPMS goes off and I pull off side of I-25 as there was plenty of room before looking at why the warning. I get stopped and I’m showing 80psi on the LR of the toad so I get pressure gauge and cautiously check with 36psi . Reinstall the sensor and by the time I get back in driver’s seat it shows up correctly on TPMS. My heart didn’t need all that excitement.
We finally get to our planned stop Kaycee RV Park, only coach there. Paid the 35 dollars cash and told there was 3 pull thrus with the water turned on and since our next stop was a Harvest Host I decided water was required. It had been raining all day, very little gravel in the park but most sites looked good. Well I chose the wrong one, looked good until all of the sudden the left front started sliding left and sinking, I immediately stopped. When I got out and saw (pic below) I thought great way to end this day. We decided to disconnect the toad and attempt to back out the same way I had gone in. Drive axles appeared to be on solid ground and if the front would just stay in the ruts I had just made maybe we would make itwhich we did. Ended up in Buffalo, WY in a different park 45 miles north with plenty of gravel and beer.
I do not recommend Kaycee RV Park even in good weather, it was quite run down. We are glad all ended well and just chalking it up as part of the adventure.
