- Dec 19, 2019
- Dutch Star
- 2021 Willys
Yepppp, refer to my adviceOne other thing, after putting the door lock back together, we decided to leave the coach. Closed the door and found out it wouldn't open again. The two halves of the mechanism were slightly misaligned not allowing the latch to actuate from the outside. So, now being stuck outside, I'm thinking I should have installed the power window wires in the front bin. Got it open pulling on the handle as hard as I could. Re adjusted so it works and the wires are going to be installed today!![]()
Just as I was pulling on the handle, I actually was thinking about that. Wires installed this morning.Yepppp, refer to my advice![]()
I added the wires to the bay below the electric driver window to be able to operate that window in an emergency lockout.Not sure about Jim's DS but unfortunately our drivers side window is electric..... Wish it were mechanical.
As did I. Also suggest adding the cable pull to unlock the compartment below the window in case that was locked when the entry door wouldn’t open.I added the wires to the bay below the electric driver window to be able to operate that window in an emergency lockout.
Electric. I installed wires from the switch to the front bay. If locked out, open the front bay and connect the two wires to the + & - on the fuse board to make the window go down.Not sure about Jim's DS but unfortunately our drivers side window is electric..... Wish it were mechanical.
Yup, that too.As did I. Also suggest adding the cable pull to unlock the compartment below the window in case that was locked when the entry door wouldn’t open.
