MapNerd
RVF 1K Club
- Nov 17, 2019
- Prince William, VA
- Ventana 4326
- 2020 Ford F-150
- Yes
Does anyone else have a devil of a time getting their fueling cap off? I would say 3 out of 4 times, I stand at the fuel isle struggling to get the darn cap off. Has anyone found an easy replacement or a pass-through cap that can be used for the commercial-sized filler?
That one seems way too large @CoreyinWP. I see how it would clip on to the fuel funnel, but the opening looks too small for the filler to fit through and also, how would that even seal the filler tube? I think you should try to get your money back from whoever sold you that. They saw you coming from a mile away
You’ve seen a pass through cap for a normal gas vehicle. Basically its just a little spring loaded metal flap. I assumed there might be one with a larger diameter for the larger diesel fillers, but no dice. Apparently that’s not a thing. Everybody is worried about someone putting sugar in their tanks, I guess.What are you talking about with the pass-through cap for commercial sized filler?
That seems like just as much of a pain in the rear when I loose the key or it jams due to dirt or grime. Idk. I just wanna put fuel in and go and not fiddle with a fuel cap for 5 minutes.May kill two birds with one stone if you're looking for locking caps. I bought two but never used them but if you need a new cap it's something to consider. Maybe Newmar can warranty replace yours.
https://www.amazon.com/gp/product/B003BHR0RK/?tag=rvf01-20
Old T-shirts are the preferred "red-neck gas cap."If you have any redneck in you then consider aluminum foil? No wait, maybe they put paper towels in the hole?
Aluminum foil is reserved for my space blankets and anti-government eavesdropping helmets. I do have some wire coat hangers around here somewhere though ...If you have any redneck in you then consider aluminum foil? No wait, maybe they put paper towels in the hole?
You just burn em off then....But if the tshirts get sopped with diesel, they become very heavy and will be hard to lift.
