- Dec 19, 2019
- Dutch Star
- 2021 Willys
Last trip I noticed a very small amount of hydraulic fluid on the top of my grill in the second bin, curb side under what I assume is the balancing cylinder for the FWS. I checked all the fittings, and they were tight. I then cleaned the area on the cylinder and fittings, put a large piece of white cardboard where the grill was and we took off for a week camping at the Tampa show with the NKK. While there, I had the techs from Newmar look at it and they surmised the leak was apparently coming from one of the wire grommets on the solenoid which had turned pink instead of white. (see pic) They didn't have one in stock at the time, so I figured I'd find something after we got back home. No leak detected on cardboard after 6 complete slide operations.
Once back home, I called HWH, explained what the part was, and they were out of stock with no idea if or when they would get them. I was surprised when they quoted 240 something dollars. I then called Newmar. They did have them in stock. I asked them "how much". It's not really clear as to what happened after that as I believe I passed out for a short time. If I remember correctly it was just about double from the HWH price... but they have them. Question is: Has anyone had this issue and possibly found an alternate supplier? There are no discernable markings on these.
