Rd1
- Feb 16, 2022
- ̶N̶e̶w̶m̶a̶r̶
- ̶L̶A̶D̶P̶
- ̶F̶L̶
Update. The coach was plugged in when this happened. I thought to myself "self we are told it is better to run the slides with the engine running". I tried to start the engine. Chassis batteries were dead. I jumped the chassis batteries with the house batteries. Since the coach was running, I started the generator to exercise it. With everything running, I got the coach out and drove about thirty minutes to a fuel stop. Fueled the coach up and put back in the barn. with the generator running and the engine running I tried all the slides and they all worked. I guess I am confused. Where does the coach get power to operate the slides? I thought it was the house batteries. They were at 13.2 during this.
HWH FWS is powered by the chassis batt. With the dead chassis batts while pluged in, you may want to check the solenoid in your power bay to make sure it is functioning. What ever model solenoid you have, either white rogers or amatek, they are both junk and have a tendency to fail, specialy when the coach is plugged in long term, the solenoid ends up with a shorter life.
As for slide ops, they are all different from early years to the late year models. earlier years 2016 and earlier, engine had to be off before you could operate the slides. 17-18 some slides would close-in with engine running, but not open. Later model years, I think the slides operate with the engine running, which is the way it should be to supply sufficient charge to the batts. HWH FWS needs sufficient batt voltage to op safely, unlike the elec ones which need sufficient amps
