MapNerd
RVF 1K Club
- Nov 17, 2019
- Prince William, VA
- Ventana 4326
- 2020 Ford F-150
- Yes
Yeah, neither TruckMap or RVLife seem to do traffic-based re-routing, though they do both reroute based on route deviation (eg. you missed a turn). I think I actually know why this. Behind the scenes, TruckMap, RVLife and Sygic (forgot about that one) are all most likely using routing services from Esri/ArcGIS - which is one of the few that actually supports robust routing restrictions. Under the hood, it's the same data from HERE/NAVTEQ that Garmins use - Garmin just built their own routing services instead of using the ones from Esri/ArcGIS.
Garmin building their own routing service on top of that data allows them to tightly control their experience and cost. Whereas by using the Esri/ArcGIS routing services, you are subject to their cost model which is pay-by-the-route. So, if you have to pay n-dollars to Esri/ArcGIS for every route generated and then the user misses five turns and you have to reroute them 5 times, or they run into traffic 2 times and you have to reroute them, that multiplies the cost of a generating the route for a single trip by the number of times you had to re-route the user. At scale, that can really eat into your limited profits.
So there are certainly benefits to each.
