Russellvh
- Nov 18, 2021
- Home based out of the Colony, Texas
- Forest River
- Wildcat Fifth-wheel
- 2019 Ford F-250.
- Yes
and change fliters.From what I've read, not a Chemist, the Gasoline will separate from the Diesel (lighter fluid). This can be the issue. You don't get a nice blend but pockets of Gasoline, which can be bad news for your very expensive diesel system.
If it were me, I'd drain the tank completely, then flush with some fresh diesel just to be sure. BUT that is just the way I'd do it (paranoid)
Good luck..
If you have accidentally put gasoline in a diesel car, it is generally recommended to take immediate action rather than waiting to consult with a specific manufacturer like Cummins. While Cummins is a renowned manufacturer of diesel engines, they may not have the specific information on how a different manufacturer's vehicle, such as your IS (presumably Lexus IS), would react to such a situation. Here are some general steps to consider:
It's worth noting that the exact impact of gasoline in a diesel engine can vary depending on factors such as the amount of gasoline added, the engine design, and other variables. Promptly addressing the issue by seeking professional assistance can help minimize the potential damage and ensure the best course of action for your specific vehicle.
- Do not start the engine: Starting the engine can circulate the mixed fuel and potentially cause damage.
- Contact a professional: It is advisable to call a roadside assistance service or a qualified mechanic who can guide you on the best course of action. They have the expertise and experience to handle these situations appropriately.
- Drain the fuel tank: In most cases, the fuel tank needs to be drained completely to remove the contaminated fuel. Depending on the vehicle, this may involve removing the fuel tank or using specialized equipment to pump out the fuel.
- Flush the fuel system: After draining the tank, it is important to flush the fuel system to remove any remaining traces of the incorrect fuel. This may involve replacing fuel filters and purging the fuel lines.
- Refill with the correct fuel: Once the fuel system has been flushed, refill the tank with the appropriate diesel fuel.
