Green light for water pump does not turn on
Buly
RVF 1K Club
TGO Titusville FL
InTech
In-Tech Dusk travel trailer
Aluminum
Lexus GX460
The little green light for the WP on the control board inside the coach does not light anymore, after changing my pump? Can't figure it out why? The On/Off feature works, but the indicator light does not. Any ideas?
My hunch is your water pump controller. Either a spade disconnected or it's bad. Location is left (forward) wall of wet bay, as you know.
Neal, I even replaced the controller. But the installation is a nightmare. They left zero slack on the wires, and mostly hidden behind the white board. Even I had to use a mirror to be able to see what I was doing.
Is the green light not coming on at any of the switches? Mine has 4 if I recall: kitchen sink, each bathroom, wet bay. I really think it has to be the controller, it's simply a latching relay.
All four are off, but the switches work.
I'm not at my coach but are you sure the wires are connected to the correct locations on the controller?
Here is a picture I pulled from my phone pictures history, if it helps. Upper controller is water pump, don't look at bottom one for custom sanicon control.
Thanks Neal. I will compare it to mine.
Here is mine. I even run a special ground wire to the GND spade. Maybe I have to hunt for the two white wires?
