TXfreeze
RVF VIP
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
Yesterday, the fridge side of the rig was in direct sunlight About 75 F outdoors but the side of the fridge surface temp was 95 F and the thermometer inside the fridge read and still reads 70 degrees F, the setting is on coolest, there are no airflow issues, the fins are moist but barely cold, the freezer appears to be working, No error codes displayed 12 volt seems like it’s being supplied, I took off the outside cover for the first time and the absorber coils are hot to the touch as it should be, I’ve read that it can take from 12-24 hours to cool the fridge but so far no change and it’s been more than 12 hours, also today is overcast with sun beating down on that side. I haven’t tested the cooling fans, I need to locate that or Thermistor yet I placed a small battery fan inside but no change.. I’ve tried to cool on propane as well but no change the pilot shows lit when it’s on. Is there anything else I should check or try before calling a repair guy? Thanks
