- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Inverter/Charger. With the larger battery banks found on a DP there is no need for a converter. This is one of the minor stumbling blocks you run into if converting your battery bank to a 24v or 48v system. Somehow you still need to include a good 12v source to run the higher load 12v stuff like slides and jacks.You mean the inverter/converter? I assume a large MH has the consolidated unit.
Yes, you still need a converter. An inverter does not provide 12vdc to anything. It uses it to make 120v AC.....Terminology is important sometimes. You have converters, inverters, and consolidated units that do both. But they are separate functions of the same unit.Inverter/Charger. With the larger battery banks found on a DP there is no need for a converter. This is one of the minor stumbling blocks you run into if converting your battery bank to a 24v or 48v system. Somehow you still need to include a good 12v source to run the higher load 12v stuff like slides and jacks.
Right but there is no need for a converter (120v AC to 12v DC) when you have a big enough 12v battery bank to handle the 12v loads. Conversely the use of a bigger inverter (12v DC to 120V AC) is made possible by the same higher capacity battery bank.Yes, you still need a converter. An inverter does not provide 12vdc to anything. It uses it to make 120v AC.....Terminology is important sometimes. You have converters, inverters, and consolidated units that do both. But they are separate functions of the same unit.
You will need a lithium battery isolation monitor. You will have to change settings on your inverter as well. You will.habw a Magnum or a Victron.Allen,
As near as I can tell, the only additional equipment needed is a BIM. All the other changes are completed on the panel. So, if there is more, I am not aware. I asked yesterday and got very little info. The battery I am looking at has self contained heat and BMS
You are calling your convertor a charger, that is all. Terminology.Right but there is no need for a converter (120v AC to 12v DC) when you have a big enough 12v battery bank to handle the 12v loads. Conversely the use of a bigger inverter (12v DC to 120V AC) is made possible by the same higher capacity battery bank.
My Bay Star had a converter which provided 12v DC because it only had two 12v house batteries (typical for a gas class A), and even after I installed a large Li-ion battery bank I retained the converter to provide 12v DC because my battery bank was 24v (charging up to 32.8v with solar) and while it wasn’t highly efficient, the converter got its 120v from the inverter. So by using a 12v converter powered by a 3kw Victron inverter off a 24v battery bank, I was still able to make 12v DC for the slides and jacks.
With the battery banks on DPs there is no need for a converter because you have a big enough 12v battery bank to handle the loads and it is charged by the inverter/charger when on shore or gen power - the reason many say to run your slides in and out either on shore or gen power, although with a healthy, well charged battery bank this isn’t necessary. Converters are needed on trailers, campers, and most gas coaches because they lack a sufficient battery bank and a big enough inverter/charger.
I do not believe inverter, converter, and charger are the same. Some may combine functionality, for example my Victron inverter is also a charger. I can isolate it so that it's only an inverter and not a charger.You are calling your convertor a charger, that is all. Terminology.
Sorry @Neal an inverter is an inverter, however an inverter/charger has the function of a converter, because a converter is nothing more than a charger designed to supply a continuous current! Or put another way a converter is a robust 12vdc charger.I do not believe inverter, converter, and charger are the same. Some may combine functionality, for example my Victron inverter is also a charger. I can isolate it so that it's only an inverter and not a charger.
