Question How Often To Sanitize?
@TJ&LadyDi - looks like that kit is for about 100 gals. We have a 105 gal FW tank so it should be fine. Do you have to use 2 kits?
We don't let water sit in the tank, it's drained every time we get home.
We sanitize usually once a year. RV Geeks has a very good You Tube video on it.
Well here is a video regarding sanitizing fresh water tank. Typically we do this, as others have stated, at least once a quarter or if the tank has been unused "for a while". Also we do not drink the fresh water from the fresh water tank but do cook with it.
We sanitize in the spring, before leaving Florida for our annual trip.
Anybody ever test their water? I see the TDS meters are cheap and there’s kits to test more specifically which includes bacteria, which I guess is the main thing you would want to know about.
I recently bought a used unit and even though I disinfected the system I’m thinking about doing some testing. (Everything seemed very clean on this unit - even the black and gray tanks.)
City water does have a small amounts of chlorine. I frankly don't worry about it very much.
Here's some Food for thought,
One should sanitize to remove harmful germs and pathogens, but over-sanitizing can cause one's immune system to react negatively to a germ-induced environment. This can also draw allergic responses from the body when it is exposed to an environment less clean than the one in which it lives.
