MOD Just bought a Dometic CF 80 cooler
When I had the fish flash frozen, they suggested to set freezer to as low as it would go. Might be able to set it higher for other food but didn’t want to risk it. I do like the insulated cover you got, nice upgrade.
For anyone thinking of ordering a 2020 DSDP, there is a typo in the Dutch Star brochure for 2020 -
I tried to leverage this into a free Dometic freezer option but didn’t get too far with my dealer. You might be more successful with yours. [emoji16]
Sent from my iPad using Tapatalk
Interesting ?. All bargaining chips appreciated.
On the one we had, any relationship between the temp we dialed in and the actual temperature the unit delivered was purely coincidental. To get to 34 degrees, you had to set it at 27 and then if the weather got cold, you had to watch it or it would freeze.
I’d be interested if others have had similar issues.
Stayed with friends for a weekend in their Grand Tour this summer and they had a similar Dometic unit. Since it was my beer, I was responsible for setting the temp but had the opposite issue. Had some slushy beer the next day and had to raise the temp setting higher than I would have guessed to keep it from freezing.
Larger cooler in 2020 DS, now is CF-110. Now I can store more beer?
Who knew joining this forum would cost so much...
I bought the same cooler two years ago when I got sick of buying 20 lbs of ice every two days while on our trip. It really is a nice item to have. I used a MORryde freezer tray that is much lighter than the standard Newmar item, yet it's very sturdy and allows the freezer to come way out of the bin. Pic is from online, not my unit, but you get the idea.
Larger cooler in 2020 DS, now is CF-110. Now I can store more beer[emoji3]
I think they got smart when they added 2 inches to the basement. Hopefully you still have room for a shelf above it.
I can state from experience, the "smaller" one will hold 3 cases.?
I can attest to 4 cases to be exact with CF-80. New one is in freezer mode still with fish, so not sure what it holds.
I guess I'm confused. With most of you having residential refrigerators/freezers, why do you need an outdoor unit? Seems like it would compramise a lot of storage space. Now for me it might make sense as I've got the smaller gas/110 refer. But with these beautiful units in your coaches, seems like overkill.
Yes, all valid, the frig/freezer is sufficient especially since most CG's are within some type of food store (Walmart, etc.). However, we are lovers of EXCESS. It's great having extra frig or freezer space such as @NWIP with his Alaska catches or many with using the external as beer/wine coolers. I had to keep beer in the bottom tray of the frig, not ideal but it worked, it's not the largest of frig's. Every change such as this does force you to rethink your storage and trim down. I added shelves and this also forced me to rethink what I really need to carry with me. Do I really need 3 grills? Do I need enough tools for Bob Vila? I take advantage of each of these changes to improve. I have a telescoping ladder coming and not sure where I'm going to put it as my VIAIR compressor bag is really where it should go but where is that going to go? The constant puzzle.
I do really enjoy the Dometic cooler. I'm big into protein shakes right now with playing Pickleball every day so I have several gallons of milk in there right now among wine and beer. It's also handy to access from the patio instead of going inside. I personally need more outside time!
I will likely always have a Dometic cooler going forward, it is a great thing to have in my opinion. I'll figure out storage, the cooler is a must to me.
Our external fridge (a Norcold TEKII) came with the coach and actually still worked :cool: It is either a fridge or a freezer. So far we use it as a fridge and keep bottled water, sodas and beer in it and we restock the inside from the outside. Our inside fridge is a gas/electric dometic fridge, so it lacks room. As for room in the bay where the external fridge is, I still have a lot of room in the tray behind it - I keep a case of bottled water or two, the ViAir, the main awning sunscreen addition and also some end screens for it, the extra foldable step and also the welcome mat. Still a little room left.
More on the Dometic situation:
The cooler is portable, it has (or can have) handles so it's easy to remove and even can be powered with 12V such as a car battery with alligator clips. I removed the handles from mine as I don't intend to ever remove it but you can also remove it for storage if needed such as if going on a trip that you need space and not the cooler - it is not a permanent fixture.
From what I've noticed lately Newmar didn't remove the handles. For those with the cooler and don't want the handles in the way of things it's just an allen screw that is holding the handles on, two screws per bracket. Remove and store and you'll be happy to have the handles out of the way of other things.
Neal, can you please provide link to tray. We have talked about one for our 3407, as I want to put a tool box in that compartment but want to be able to slide it out and in, Guess should have just had Newmar put the tray in there, but, you know money! How did you attach it, what waterproofing did you use, please outline detailed procedure for us folks who need to be led around some.
I have been looking at this unit as backup for house in case we had sever outage, I have not checked dimensions to see if would fit in storage compartment as the price of the thing is huge, but the reviews have been very good. Preppers like them. https://www.amazon.com/dp/B003TM2K0Y/?tag=rvf01-20
Post #12 in this thread sir.
Neal, thank you. I cannot tell from the picture does the shelf have a floor? Does it come with directions? Know stupid questions, How would I find out if this is the one which I should get for the freezer compartment in the 3407, assuming mine is smaller. Guess I could call Newmar, and I might have too anyway, have not gotten reply on 21 warranty items I want fixed. Again, great job.
The shelf bottom is a frame, no floor, and you'll likely have to build up the outer frame to get it to sit higher so it clears the basement door gasket. Some 3/4" plywood works, I think Newmar even paints there's black. No directions with it, none really needed. You can contact Newmar parts and get a quote, they wanted twice as much as what I paid for going direct and getting the cooler from Dometic (or Amazon). Newmar will often not tell you part numbers etc. to try and prevent you from circumventing them. Best to measure your area and contact Keystone and discuss with them.
In light of the current pandemic this cooler addition has been the best thing ever. If you have to evacuate for a hurricane or hunker down as you can't travel or need to avoid stores being able to stock up and load up with this is wonderful. Highly recommend!
