Lithium batteries in 2026 Entegra Esteem 29V.
RvDale
I would like to install 2 each 75 AH Battle Born lithium in place of my 2 12volt lead acid batteries. My research tells me the charger/converter, inverter and solar controller can be configured to manage lithium batteries. My main concern is charging from the chassis alternator and if it is compatible or do I need to add additional protection?
Thanks for your help.
@RvDale
First I will suggest you search this site about battle born batteries before you purchase.
Next read the posts that discuss using your vehicle alternator to charge deep cycle batteries of anykind.
The BB issues aside get some real help and consider what you really want to accomplish. Small 100 A/H and smaller batteries are not serious for anything worthwhile. The Lithium version of the lead acid so called marine-rv batteries. As for the alternator charging lithium there are a lot of myths and also good solutions. The upgrade path should also consider an alternator upgrade if that makes sense. I can help with most of that.
If you are going to have electric service most of the time it really doesn't pay for me to do lithium.
With the current pricing of Lithium and the various advantages that really is no longer true. The one advantage any miss is that while in storage, plugged, Lead Acid batteries of any sort will always draw some charge current and when the charge source is removed they will quickly loose some of their capacity immediately. Lithium does not do that.
Oh my!
Modern converters should be auto detect and you just need to train it to recognize the lithium charging profile.
First identify the converter model.
Some people add a DC to DC charger. On my 5th wheel I don't see the need due to the existing wiring not being large enough to do any alternator damage and my solar keeps up with the small draw while towing.
I can't speak to your motorhome though. I'm sure you have greater demands and may need the DC charger set up.
