Low Flow in shower of the Dutch Star
newmarokie
southern oklahoma
newmar
Dutch Star 4018
40'
450 hp Cummins
2017 Colorado, 2013 Dodge 1500 quad cab
I have terrible water flow in the shower. On the pump or hooked up to city water, no noticeable difference. I have checked flow through the sediment filter and water softener and it is good. I replaced the filter in the wet bay, it may have helped a touch, but not much. What else do I check/replace?
There are valves behind the escutcheon plate that seem to work closed, remove handles to remove plate.
Took me 3 hrs but I got every single water saver disc out of every faucet and shower head. You won't believe the tiny hole they expect water to get through!
Mark
Calcification of the shower head?
It ultimately was hard water deposits in the valves Sealyn directed me to. After I got out a dictionary and looked up what an escutcheon plate was, I got in and the valves hadn’t closed. With the shower head off, I ran both sides in and out a couple of time and flow improved dramatically. I wonder if a “winterization” with a mild HCL solution for about thirty minutes would help the system. We use a softener now, but can’t know how the system was treated by the previous owner
