Manual conflicts on GMC setup
Texas Clodhopper
Garden Ridge, TX
Ventana 4369
Longer daily
Freightliner
Cummins
2022 GMC Canyon AT4
I recently changed from a 2018 GMC Canyon to a 2022 GMC Canyon AT4 and I'm in the process of setting it up to tow. I always copy the instructions for setting up the transfer case and transmission for towing. As usual, the manual says one way under the recreational towing section and another slightly different way under the operation of the transfer case. I will follow the procedure in the transfer case section...I guess.
I installed the Roadmaster 766 battery disconnect this morning and I think that's going to work out nicely. Diode lighting tomorrow. The M&G Engineering braking system and baseplates will be installed by the dealer on Friday.
My Colorado was the same and I just meshed the two as best as I could figure out and most conservatively.
