Minnie Winnie Generator starting issues! HELP HELP!!!!!
lostone1413
I have a 1986 Minne Winnie. The Generator will only start if the RV is running and I'm using the dual battery switch. When I try and start it without using the battery switch allot of times the generator won't even click. I replaced the batteries. Both of them. They both read 12.7 volts. More then enough to start the generator. Other issues that started with the generator not starting are. If you start the generator using the dual switch everything works fine with the 120 and 12 volts inside the motor home if you leave the motor home plugged in the house outlet. When you unplug the motor home from the house and haven't started the generator you don't have 12 volts going to the motor home. At time when I start the generator with the dual switch on and everything is running when I shut off the motor home off sometimes but not all the time the generator just dies. I've had three people in the business look at it. None have figured out what is wrong with the motor home . What I was told was it was a transfer switch for the Generator. I was also told that in 86 they didn't have a transfer switch for the generator. I have to manually plug and unplug the power cord. Then I was told it could be the inverter. I was then told that the inverter has nothing to do with it. To me I feel all the issues are tied together. If I get the generator to start maybe everything else will work fine. Do you think it is one issue with the generator and the lights? If so you have any idea at to what could cause all this ??
Look first for a house battery disconnect switch. Then make sure all cables have a good connection at all terminals. My guess is there is a box with relays that your switch your using controls.
It was typical for the generator to have a receptacle the house cord plugged into, find that and plug the house cord in there.
Then we can talk about what didn't get fixed.
I have a 2003 Minnie Winnie and last week I had no problem when I hit power switch on driver side and switch near step area inside motorhome and then I could use control panel to turn on Generator no issues! Now it doesn’t work and I checked reset on Generator outside but still won’t start! The only way is to start my engine battery and have someone hold down switch near stairs and then I’m able to turn on using start on panel! What could be the problem? Thanks
Low voltage! That could be the batteries are not getting a full charge, or the batteries are getting weak!
Yes! Are you off grid or connected to the grid/shore power?
It takes hours to charge a battery fully. New people think that when the voltage reaches 14 that they are full, but batteries are more like a turkey! They have to bake in the oven till the heat gets to the middle. That of course is an analogy, but same idea.
So let us know what your trying to accomplish and I can be more specific with my answers.
Thanks it’s parked at the RV Storage place! I have a super start power pack 12 volt and peak amps 750 I bought at auto zone! Will this work? Thanks so much!
If you have 120 power you could charge up the battery. If you don't get help to take the batteries home and charge them there.
