Mounting a Parsec Husky antenna
redbaron
Staff member
RVF Moderator
London Aire 4551
Spartan
2020 Jeep Wrangler Unlimited Rubicon
I just received my Parsec Husky. How are you mounting this on the roof? It has a pass thru on the bottom, which means I will need to get creative in my mounting solutions.
Would like to see what others have done. @MapNerd -- I believe you too have one? Any pics?
@MapNerd got the one with magnetic mount. I installed mine on the top of my air conditioners. If you got the one without the magnetic base you have a lot of options I'm sure your creativity can solve. Plate coming off of a girard, etc. You could build a mount that raises it so the antenna is the same height as the girard top so you get a 360 degree unobstructed view such as the winegard rayzar OTA antenna mount does. Imagine a flat piece of aluminum with a hole in the middle, then angle down two sides at around 75 degrees, then if bends again opposite to make flanges you can use 3M tape to adhere to the roof.
