Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
So what is the diameter of a DP tire about 36 inches?from a friend of mine -
"Rettroband vs Red Diamond will have some differences, albeit minor. Rettroband has a fixed ring attached to the wheel to support the rubber in the event of a blowout, keeping the tire carcass under the wheel. Red Diamond has freewheeling rollers that let the rubber and ring spin around the wheel so the tire belting isn't further shredded by stretching.
In reality the difference in performance for an RV is probably minimal, since in the event of a flat you're stopping as soon as possible. But the rollerized Hutchinson (Red Diamond) has potential to be driven short distances even with a damaged tire where the Rettroband can't. Hutchinson is what's put inside of JLTV tires to enable them to continue moving even after all the tires are blown out."
Military & Security Lightweight Wheel Protection | Hutchinson Runflat
Following a tire blowout Hutchinson's lightweight runflats protect military & security vehicles and passengers by maintaining mobilitywww.hutchinsoninc.com
What is the outside diameter of the band? My wild guess is 29 inches. I really don't know but it is good for this exercise.
29×3.1416(or pi)=91 inches circumference.
36×pi =113 inches.
So every rotation is a frictional tearing on both band and tire of 22 inches. So it takes 5 rotations at high stress for the band tire junction to make one complete rotation around the inside of the tire. Can you see the value of a bearing???
If I were in the market, I would only consider the one that rotated, even if the price was higher. After all, how many rotations to stand still from let's say 70.
