gibsito
- Feb 21, 2021
- Grants Pass, Oregon
- Alpenlite 29rk 5th Wheel
- Six-Pac Truck Camper
- Corolla
I have a Dometic RM 3804 refrigerator in my 5th wheel that will not consistently switch from AC to LP operation. This fridge was installed by the previous owner right before I bought it in 2009. Since then it has sat on my property and never moved, so the fridge has always been running on AC only. But now I'm getting ready to take it on the road, and have discovered this problem running it on LP.
When I started looking at this earlier today, I unplugged the AC cord and the LP burner would not light, or even attempt to light. It did nothing. So I pulled the rear cover off and just looked inside at the ignitor, the ignitor wire, etc., and could not see any visible problem. So I tried it again, and this time it switched over to LP normally. I repeated that several times and each time it worked as it should. I then put the covers back on and went about other business. Just before finishing up for the day, I decided to try it one more time. This time it failed to work again - with no attempt to light.
Any idea what the issue could be?
