FL-JOE
RVF 1K Club
- Nov 15, 2019
- Frostproof, Florida
- Forest River (sold)
- Salem FSX 270RTK-X
- 2022 Ford Expedition Timberline
hear hear!I don’t look at Solar v. Generator as a thing...
Instead of contemplating which is more cost effective...ask yourself —- Do you want system diversity? Do you want system redundancy?
I had an interior screw come loose in my Onan QD8000. According to the mechanic that finally fixed it...the screw would get sucked up into the Governor, and confuse the speed control...causing it to immediately shut down. So...a legend in the industry...Onan...can fail too. To be honest...solar Systems are worthy of being called reliable. You do have to take into consideration where the sun is...but it’s something that just keeps going and going.
So instead of either or...I think having both gives me more choices. More options to pick...especially if one system encounters a breakdown.
I sure wouldn’t rip my generator out...just because I added solar AND I don’t short change the value of the Solar, just because I have a generator. They both add value...diversity...redundancy. It’s a good thing.
I'm in Prescott, so not terrible compared to Phoenix area. So the A/C isn't NECESSARY - But I appreciate all the feedback you all have given so far, I'm learning a bit.A solar generator is nothing more than an inverter, battery, and small panels. I too reside in AZ. My comfort comes by following the temperatures. From Yuma to sedona area, to flagstaff area to white mountains in the heat of summer then back down as the temps change. Daytime use of a 7000btu A/C can happen but not night time. If you try, your charge time will not catch up and you will be left with less power every day you do try.
So what part of AZ?
