Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
The hitch is rated for 10000# and the spring bars work best between 8000# and 10000# is how I interpret your numbers.A ball from Uhaul? Who knew? I didn't. Thank you! This is all good info and we were looking at Curt contraption that said 8000 to 10,000 pounds. I assume that means they really intend it to pull up to the limit. Thank you for all the advice. Best wishes!
So you know, I think that the curt and harbor freight wdh are name plate branded China sourced hitches.
I didn't say they are bad or I would not own one.
One more thing! I like the saying " an ounce of prevention is worth a pound of cure " in this case it is a two edge sword. If you take caution with loading your rig you will not need sway control.
If you have loaded wrong sway control will do no good.
I won't use sway bars because I feel (justified or not), the device stresses the tow vehicles frame in ways it was not designed to handle. Do your own research.
