Need to open tailgate while hooked
Wgb
Just bought a trailer the sales guy knew from the beginning we have two Labradors and planned on having the in bed of trk in dog boxes.
Everything was done and about to pull off when I found I was unable to open tailgate.
The question is. Is there a hitch that I will be able to open tailgate while hooked up?
why do you need your tail gate open when driveing .
I have a f150 I don't need it opened while driving but to let the dogs out for breaks along the way.
If there in dog boxes, strap the boxes down and remove the tailgate, or your probably hitting the tongue jack. See if you can find a shorter one.
This is what I came up with but there is some side to side play in the connection. So I'm not sure how it would pull..
My next option is to relocate jack further back the tailgate would work and miss the propane tanks.
What are your thoughts for my best options.
I think that puts way too much pressure on your truck hitch.
The closer you have the ball to the truck, the better stability you will have.
I've came to the conclusion that the best and easiest will be to cut the power cable to the jack and make it a pluggable and remove the three bolts and remove the jack while traveling. That way we will be able to let the dogs out to excercize and so on a long the way.
It's very easy to take the jack loose, rotate it one direction and bolt it down with the two bolts that will line up. You don't need all three bolts. This has worked for me on many trailers
just wondering some of the tail gates for the 5 th wheels they have a deep in them check them out i think you might be able to drop it like you want to.
This is very true. With an extended hitch the trailer will have more leverage with which to push the back of the truck around. In the interest of maximizing towing safety I would not be using such a hitch.
I seen someone at a akc hunt test that turned his jack sideways and was able to open his tailgate but his hitch I believe was a little longer then mine it had two holes to put his pin through. haven't tried with mine yet.
Go online to etrailer. They have extensions of different lengths made just for this purpose.
Like Roy2 said- maybe an RV tailgate would work. If not, what about one of those rubber tail gate nets?
