New Member Loaded with Questions.
Bobbydigital
Hello community! My name is Bobby, and I will be traveling and adventuring with my partner Sandy soon from a Flagstaff pull behind with 30amp service. My first initial question is the generator. I'm eyeballing a 3600 watt generac. Is this going to be enough to power everything at once if the need ever arises?
That should be fine as long as you only have one air conditioner, which given 30amp is probably the case. Also as you shop generators, test run them all and consider the quietest one, even if it costs more. A noisy generator gets annoying very quickly.
