No House Power
mwagon73
I seemed to have lost power to the house. The battery disconnect doesn't do anything. The coach battery was dead, I jumped it and everything is running fine other than a "service engine" warning. Now the house batteries won't engage or turn on. Any suggestions?
mwagon73 Some info. on the make, model, year of your coach might be helpful for forum members to assist if they can.
Have you been able to solve the problem. I am having similar issues and am interested in what you found out.
I did, I ended up taking it to the RV dealer... apparently I left the battery disconnect Off for too long... it was a few weeks. even though it was on shore power and the batteries died.. so.. the dealer recharged and for a bit and they are back on. a bit of newbie issue and my fault I guess.
If you have lead acid batteries, this little trick will help your batteries.
Go to Lead acid battery renew
If you have Advanced Glass Matt (AGM) you may end up purchasing new batteries. Most often AGM will not tolerate being dead for a few weeks. There have been survivors though. Good luck!
