Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
I did not see that problem⦠probably due to the different model of my system. When I filled up the unit, it also filled all of the lines and pumpsā¦@Richpatty I used a section of clear hose on the outlet side to verify I didn't have any air left in the system. Brian told me to run the summer loop pump after my initial fill, and I could hear the pump cavitating several times. This took about 45 minutes before I stopped seeing bubbles and the pumps stopped cavitating.
I didnātā¦. I figured I got out 95% of the old fluid with pumping it out and gently (10-15 lbs) blowing out the rest with a compressor. I thought about using water like some have said (and ITR says as well in their instructions), but didnāt want to leave any water behind and weaken the new fluid (although it was probably unlikely). Some folks use new fluid to push out the old, but at the cost of the fluid, I didnāt know if it was worth it.Did you have to any flushes to get the old fluid completely rinsed out?
