Joe Dutchstar
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
This is how Newmar wires these units. Wire nuts but no electrical tape to secure them. I'm no electrician, no clue what's going on here.Neal, I'm no expert or electrician but stranded wire spliced to solid wire using a wire nut sounds like a bad connection just waiting to cause an issue. Not sure if the wire gauges are the same . You might want to consider a crimped Butt connector for this application.
Good point. I guess the practice of wire nut connection between solid and stranded wire is more common than I realized.Stranded wire to romex is used all the time with a wire nut - look at your ceiling fans, recessed lights, outdoor lights. All of those have stranded wires and your home has solid romex. I've not had a problem and I just replaced 2 outside lights. I agree that there should be no heat if the connection is solid.
I was thinking the same thing. The next best might be the Wago Wall-Nut connectors as they are similar in concept to a terminal strip.I think the safest connection is a terminal strip that you land a wire under each screw terminal with a ring crimp connector crimped onto each wire. Something like below.
https://www.bing.com/th?id=A2fbeac3...=110&h=110&c=7&rs=2&qlt=80&dpr=1.1&pid=SANGAM
