- Jan 19, 2021
- Ventana 3427
- Freightliner XCR
- 6.7 ISB 360/800
- 2001 Jeep Wrangler
That switch on top is a way to run your system for 3-5 minutes and get any air pockets outHi all! I took a chance and filled the empty tank about 3/4 full. After listening to the pump cycle on and off about 10 times I saw the level in the tank I just filled go down to about >1/3. Now the unit is working!!even when I turn on both zones of floor heat and the water heater!(AC) don’t know if there’s a way to prime the system or an easy way to flush it out but this Newman newbie will definitely study the ins and outs of diesel/AC water heaters a whole lot more!
ITR told me it didn't matter, but it will change color more like brown that alarms peopleHate to say this but I'm guessing you have a hydronic fluid leak. You should very rarely have to add fluid to your system. We had a slow leak that Newmar techs couldn't find at first. When they changed our black tank sensor system to a pressure type, they went behind the pegboard bay to the tank and noticed damp insulation in the area. They found the leak....
Unfortunately I don't know where your fluid reserve tank is... Ours is in the engine bay.
Here's the fluid that's used in my rig.
Century Chemical Aqua Hot heating systems Transfer Fluid RV
Aqua Hot boiler anti freeze RV heating systemswww.flemingsalesoem.com
A DS friend said not to mix colored fluid. He reported he added red fluid to his and it jelled his fluid. But I've also read that mixing isn't an issue..... All I know is I carry the exact fluid in the link above.
Thanks Steve.....my leak was right at the circulating pump after I changed out pump. Think I was to paranoid how tight to tighten since pump is plastic and it has a brass adapter that screws on. Not leaking at moment.Check the fittings on the top of the Oasis boiler for boiler fluid (wet or crusted). There is a known problem with these being loose and they leak. We had fluid around the fittings that I would wipe up - after a few times did some research and found that these may not have been installed correctly at factory. Pinching off the hoses and cleaning/redoing the connections seems to have stopped our 'slow' leak. (Prior to this I was adding fluid every few months, but could not find a leak anywhere else)
Thanks so much for your suggestions!Check the fittings on the top of the Oasis boiler for boiler fluid (wet or crusted). There is a known problem with these being loose and they leak. We had fluid around the fittings that I would wipe up - after a few times did some research and found that these may not have been installed correctly at factory. Pinching off the hoses and cleaning/redoing the connections seems to have stopped our 'slow' leak. (Prior to this I was adding fluid every few months, but could not find a leak anywhere else)
