Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
@Richpatty are you referring to the Magnum remote when you say "advanced head unit"?Yes. I updated it to the advanced head unit…. Well worth it if you are going to stay with the magnum. I think they have a newer one now so check for backward compatibility.
@Richpatty how did you do the wiring in order to piggyback your victron smart shunt off of the magnum shunt? Series?Yes….upgraded to the ME-ARC50, but that was in 2018 and I think there is a new model for it now.
I wired mine in series which seems to be working. Curious what yours looks like if you have a pic of it...Actually I just hooked up the wires from the magnum right to the Victron smart shunt in the same way you would hook it up to the Magnum shunt. Although the two shunts report slightly different numbers, they are usually close. Generally I go by what the Victron says as it is easier to check via Bluetooth rather than going to the magnum display up front.
Hope this helps
I can take a pic if needed.
Rich
Hi guys,Hi,
I know this is coming a long time after your note, but I hope you can still see this and are still here.
I have had the oddest thing and extensive testing with input from battleborn, magnum, a genuine rv expert electrical troubleshooter and a ton of headscratching from all......and that is, that with a bank of four battleborn 12v 100aH batteries, all four known to be good individually (we substituted four others, also known to be good and problem is the same, so we know it is not the batteries), and while the batteries register as having a full charge (all settings are absolutely correct in the magnum...I know you have heard this before, but this is the cse)......as soon as the charge is full and the batteries go to rest from a resting voltage of 13.6, the batteries as a bank, drop down to 13.2 in a matter of 10-20 minutes (longer in daytime with solar panels but still "precipitous") and then upon an inverter load, with just a fridge and some 12 volt lights, kind of thing, it is only a matter of another 20 minutes or so before the batteries threaten to go below 13 volts (even at 13.2, the specs show that this is only about a 30% charge but one way or the other, this happens 100% of the time.
there are no other known loads...no ACs runnng...yes, the frdge is a full size but even there, we have replaced it for unconnected reasons and the problem still exists, so it is not that.
we have also tried TWO separate 2812s....both working and tested and STILL no change in the problem.
we can find no ground issues, have triple checked all wiring, have a victron small shunt spliced in so we can also see the voltate on our phone and both the magnum readout inside and the phone show, within a tenth of a volt or so, EXACTLY THE SAME ISSUES.
needless to say we are at wits end.
given your electrician status and that you are an RVer as well, can you opine on this mess? (the panels are connected to a midnite solar controller....all is well, there, too......but even with the batteries showing a full charge and turning the entire solar array off, the precipitous drop is there every time.
tonight, from storm condiitions, the shore power went off and sure enough, from a full charge to 12.9 volts was greased lightning.
can you help?
tnx in advance to you and all and I apologize for th e length of this post but there is a lot going on as you can see.
