Old Magnum MS2812 and new Lithiums
Please complete these connections
hello Kevin,
forgive what probably should be obvious to you, but when you say "complete", you mean you want a diagram of what goes to "where", right?
nsr,
I have read the entire post and there is alot of good info. I run an MS2812 and 3 206Ah SOK batteries. It was Rob that said that settings could vary and not be wrong. With that said here is how my inverter settings go.
CUSTOM
Absorb 14.6
Float 13.8
Equalize 14.5
final stage silent
rebulk 12.8
LBCO 10.8
float time 30 minutes per 100Ah
I know there will be some screaming and gnashing of teeth on a couple of those settings, but it has been working well since January. I derived those numbers off of recommendations on this forum and the SOK forums.
There was a post on the SOK forums from Min Wang. He is an owner or engineer for SOK. He answers most of the tech questions presented. He had a post on there at one time that batteries would go to 13.0 to 13,1 and stay there for a good time while in use. That has been my experience as well. There is a youtube video from a gentleman that full time with a MS2812 and I believe battle born batteries. Very informative. You might go try and find it.
Oh, and equalize time to the min. setting 0.1
nsr,
CUSTOM
Absorb 14.6
Float 13.8
Equalize 14.5
final stage silent
rebulk 12.8
LBCO 10.8
first, thank you so much. next, I did have "equalized" to, essentially "not"...meaning set as you indicate.
as to the rest, I admit to being a bit overwhelmed right now...I have recently had a very bad bout of lung cancer surgery and my life is upside down right now (although the short version is that I may well have beaten it.....won't know that for a couple of years)..............so, as I put it these days, "molehills for others are mountains for me" right now.
that said, I love this forum and the people in it...and very grateful as this whole "instant" (a legal term for the matter at hand) mess that my posts and yours contemplate have prevented me from, in so many words, having an adequate battery backup when power goes off, which it does in my area, more than it should.
THAT said, between here and yanking on the sleeves of some people also much smarter than I, are, I am sure, going to help me pull this through and sooner rather than later.
in this process I became quite familiar with the settings in magnum for these batteries, and while I would agree that a few of yours might raise a few eyebrows, they would seem to do the trick, nevertheless.
as to "SOK", that is a great find and I thank you for everything.
ps i am believing more and more, prompted initially by a post here (apologies as I do not recall who said, but I think is was Kevin) that despite the readings on both magnum's panel and the victron shunt, saying that the batteries get fully charged, I am really doubting that this is actually true. if, indeed, that is the case, and the symptoms and my setup would lean in that direction, then that obviously begs the question about "why".
i am going to stay the course here until it is done, although it may take me some days to respond to do all that i need to, depending on what local help I can dig up and when.
hello Kevin,
Yes! The pictures aren't obvious!
If you want, looking at the drawing from bottom right=1 and top right=4 . Tell me what batteries are hooked up to the buss bars. Include the polarity!
I would also like to know the ground to frame information.
certainly. i did include, I think, two photos of the ground but in the process of getting this done, I will make sure that we include it.
i ask your forgiveness if this takes me some days to get together, but please do not infer that this indicates some sudden lack of interest. these components are all in a smallish compartment, it may mean unclipping this and that to be sure the diagram is helpful and that will mean my getting some help on this end, which may not come until this weekend.
but kindly stand by....and thanks again.
PS did it mean anything (in any context) that where 1/0 cables are used to go from the array to the rest of the system, rather than what I think should have been there as 4/0 of the battery bank?
You can’t go wrong with 4/0…at least with the main ground and positive leads coming off the batteries, but 3/0 or better wouldn’t hurt even between the batteries. No one ever regretted too much cable capacity…
What you want! (In above Pic)
The picture isn't clear that is what you have!
You showed the ground lug, but explain your reasoning for it!
My preference!(in above Pic)
The cable size is not going to be the problem under low load! So for trouble shooting don't change that. If you want to upgrade later that's fine
On the first diagram, I can't tell if your power is being drawn from (cables from one battery)one battery,or each end of the bank!
Because that issue is significant clarify that for me!
got it all. the ground was there when the factory first produced this trailer, which included 3 asto panels, a midnite solar controller and the ground wire you saw. when we changed to what we understood to be a "drop in" replacement, we simply left it there, used it again the way it had been previously,..but changed all the battery to battery wires and those off of the array, as well.
as to the cable sizes, i am glad to say I am learning fast and actually guessed you would say what you did...and for now, the loads when shore power goes off, are, indeed, small. HOWEVER, one wonders if 1/0 rather than 4/0 might be affecting the charge currents coming in, although even there, my guess is likely not....i note that when in bulk and absorb charging, even when amperage is three figures for a while, it does not approach the max handling of the 1/0 cable that is on there..so I am going to change it but as you suggest, will leave it all alone for now.
meantime, I received today, appropos this thread, the following chart from my cable supplier and put this link here to try to give a little back to all of you here. hopefully folks here will find it useful (I note the specs on 1/0 vs. 4/0...also, fwiw, I always order UL multi-rated cable):
OK I found what I wanted in the pictures.
Now on to my second thought.
The only difference is the batteries right?
Or is the inverter different?
glad to hear that!
there is no difference. the batteries are the same ones that are in the pictures....in trying to isolate the problems, I tried a different set of four batteries of the same exact model, albeit a couple of years newer, and that did not change the issues I described here. ....................so I took out those newer batteries (which are now in another installation that is completely unconnected to the one you are helping me with...and which is not part of the trailer's ecosystem......IOW, for these purposes, it does not electrically exist)...................and put back in the older ones...which you see in the pictures.
in the process of all this swapping, all eight individual batteries (two banks of four) were independently charged without issue, by a standalone victron charger and all were normal.
the original inverter was eight years old, and I replaced with a newer one...same model.....to see if IT would make a difference and it did not. I then had the older one also tested by an authorized magnum distributor, and they pronounced it completely healthy, but I left the newer one in, and have kept the older one for emergency backup, since it is still working perfectly. IOW, both magnum 2812s performed the exact same way.
I also tested two separate magnum panels...the original one which came with the trailer, and a new one which I obtained for this purpose (to try to eliminate all electronic equpiment as a source of the issues) both panels performed exactly the same way and had no effect on the problems...but I left the newer one in, although you are not seeing that in any picture.
thank you, kindly, still!
I pulled up the 2812 manual.
I will not explain my logic, but I would try disconnecting the system ground to frame.
If I had a clamp meter I would test for a loss on that cable, but testing by disconnecting will suffice.
Don't worry though I will tell you My thoughts If it takes care of the issue.
first, thank you.
I am not sure I am surprised, and I am impressed by your suggestion...have genuinely felt since day one here that you had your arms around this.
I hope, however, you will still permit me to ask the following (my perspective includes that I am a longtime amateur radio opererator who is going to use some of this solar power to run what is called "emcom", an acronym for "emergency communications", which I am interested in to help people in emergencises, such as hurricanes).......and I have for many years, always understood the need...in many areas, never mind that I am no expert in this area as you obviously are............... for grounds for performance, and/or safety). That said, then, and if I may:
1. where would you make the disconnection? right at the frame, itself?
2. would you have made this same suggestion if these were not lithiums but rather the original AGMs?
3. do you think the ground was a bad idea to begin with (I am wondering why the factory put it there in the first place)
4. am I the first case where you concluded that the ground was a possible or actual issue (due to the above, I am well aware that, generally speaking, grounds can also be sources of trouble as well as wellsprings of performance and safety, so I am not suggesting you have not discovered fire on this one)
5. is the suggestion related only to magnum or do you see issues with other equipment performing the same function, such as midnite or victron, just to name a few (to wit, I am about to finish creating that seond unconnected system I mentioned, and there are plenty of places to ground equipment with instructions to do so..such as with midnite's combiner box, through which on this SECOND system i keep mentioning I am, indeed, using their combiner box which will also go to chassis ground, albeit in the trailer rear, where I had a ground busbar type strip put into the trailer at the time it was made, albeit for radio purposes (without proper grounding of various kinds of equipment, one of the issues can definitely be heavy radio frequency interference with receivers and transmitters.
6. because "grounds" in so many areas, can be related to safety or performance or both, even as you are reluctant to discuss your logic, would you consider giving me at least a most basic, general idea as to why you have come to this conclusion?
you asked me about this ground previously, so it does not surprise me that you find that an area of interest.
and again, thank you so very much!
first, thank you.
ps that ground was, indeed there from day one, in a system which used a magnum 2812, and the non lithium batteries always performed flawlessly, with none of these issues, so I am trying to simply understand, without asking you to make comments you are not comforable making at this point, what it is about this present problem that makes the ground suspect now but never before...and I trust/hope you will forgive me for belaboring this a bit?
pps..sorry for stutter stepping, but I do have a clamp meter, just fyi......a kleintool and a fluke, both..although I am not unwilling to disconnect to see, either.
