MemoriesByTheMile
RVF 1K Club
- Mar 8, 2021
- Where ever the road takes us
- Renegade
- Ikon
- 45’
- Freightliner Cascadia 126
- Cummins ISX 15/600
- Yes
Yes, it ran for a few minutes and then shut down.Jim, have you tried starting the generator?
Power and fan on. All others (including heat) are off.What do the lights on the oasis control panel in the basement show? Is there a fault there or only on the silver leaf control screen?
The generator shut down or the Oasis?Yes, it ran for a few minutes and then shut down.
Everything seems to be working. Everything except the Oasis, that is.Do all your other appliances, lights, and outlets work? The inverter may need to be reset.
Check/cycle two breakers in half bath for hydronic heater. Make sure coach see's 50A coming in. Will diesel burner run?
Yes, cycled breakers. No love.The inverter is not used for OASIS.
You'll need shore power 30 or 50A or GEN to use the electric elements (AC I/II)
Hot water (summer loop) and zone 1 and 2 fans are 12V powered, as long as OASIS is able to make heat
OASIS can make heat either by shore power and electric elements or diesel burner
Your photo showed a zone fault, go to the silver panel wall mounted on the side of the OASIS unit and see which exact zone is faulted. You will likely need to replace a pump and 10A fuse that is blown associated to that pump. You can try just fuse first but 99% chance it will immediately blow.
I hope you're still going south tomorrow and you've added some electric heaters to get you far enough south that the heat pumps will work.The code indicates a bad ground on the RV-C Node (Oasis part) or more likely, it is failing and needs to be replaced. I'll have to pursue a solution when I get to Florida.
Yeah, it's not going to be bad. It's just a bummer to start out with problem, especially after all the work I put into getting this crazy rig in order. But it-is-what-it-is, right?I hope you're still going south tomorrow and you've added some electric heaters to get you far enough south that the heat pumps will work.
Hopefully it'll be a easy fix.
Seems like this is almost always the case with new or used; these rigs have a lot of temperamental systems and its pretty rare to take a trip where nothing goes wrong, regardless of the amount of prep, improvements, and neurotic over-maintenance habits.Yeah, it's not going to be bad. It's just a bummer to start out with problem, especially after all the work I put into getting this crazy rig in order. But it-is-what-it-is, right?
Our first stop has a bath house, so we'll be ok. And when we get to the resort in Florida, we'll have all the hot water we need.
It's all good!![]()
